Camera settings for s23 Ultra
(Topic created on: 10-13-2023 11:34 AM)
A4109
Any suggestions on setting up the camera on s23 ultra my photos are really not great 😔
3 Comments
AxaCan
Look at this blog about photography. This is the European English language website of the Samsung community. A wealth of information!
Helenna
Hi, We suggest you to perform Wipe cache on your device.
This will not erase personal data on the phone. It deletes temporary cache files in the phone.
1) Turn off the device.
2) Press and hold the Volume Up key and the Power Key.
3) When the Android logo displays, release all keys.(("Installing system update" is displayed before displaying the Android system recovery menu options).
4) Press the Volume down key several times to highlight “wipe cache partition.”
5) Press the Power key to select.
6) Press the Volume down key to highlight “yes” and press the Power key to select.
7) When the wipe cache partition is complete, “Reboot system now” is highlighted.
😎 Press the Power key to restart the device.
Also, we recommend you to perform camera reset for the camera issue and check if your issue is solved.
Open the Camera app >> tap Settings or Gear icon located on the upper-left corner >> tap Reset settings >> tap Reset to confirm.
