Clicking Sound When Texting On Samsung SE 23 FE
(Topic created on: 12-14-2023 02:38 PM)
Tlew
 The sound (clicking) when texting on my SE23 FE is very annoying to others.
 How can I turn off the clicking sound?
7 Comments
RedDogRabbit
If you're using Samsung's Keyboard, it's going to be in the Keyboard's settings. Open the Samsung Keyboard & go to it's Settings & find Sounds & Haptic for the Keyboard & Toggle Off Sound, or if it uses a Volume Slider, slide it off.
I use SwiftKey Keyboard, but looks like you can Toggle Off the Keyboard Sounds from Settings > Sounds & Vibration.
Tlew
I'm using the Samsung Keyboard ... but I don't see 'Sounds & Haptic' in the settings. Hmm???
RedDogRabbit
Go to Settings > Sounds & Vibration > System Sounds > Samsung Keyboard & Toggle it OFF.
Tlew
Got it ! (volume slider).
THANK YOU VERY MUCH !
(and my wife is very happy!)
Helenna
Hi, just to confirm have you tried the steps as suggested by the RedDogRabbit ?
Please let us know if you are still facing the issue after performing the steps.
Tlew
After RedDogRabbit's help, I no longer have the issue.
RedDogRabbit solved my problem. And I am really appreciative. Thanx RedDogRabbit !
Helenna
Hi Tlew, we appreciate your efforts in trying all the troubleshooting steps on your device and your issue has been resolved.
Thank you RedDogRabbit for your suggestions and helping out to solve the issue.
Please take the time to accept the comment that you find helpful as a solution by clicking on 3 dots and tap on "Aceept as solution" and helps others with the same query.
