06-17-2022 12:58 PM in
Galaxy SHi every body,
How install other option like Alexa or Hubitat in the Device Control panel from the notification menu?
Thanks
- « Previous
- 1
- 2
- Next »
06-20-2022 04:39 PM in
Galaxy SHi, please try the steps to setup Amazon Alexa with SmartThings and check in notification panel. https://www.samsung.com/ca/support/mobile-devices/galaxy-phone-set-up-and-use-google-assistant-or-am...
02-19-2023 02:50 PM in
Galaxy SThe Device Control menu still don't have Alexa option appear in the Apps Option dropdown menu.
How do we add third party app into "Device Control" >"Manager apps" list?
02-19-2023 03:13 PM in
Galaxy SI don't know if you can add Alexa (the app) to Smart Things, but it should work if you choose Alexa as the voice assistant in Smart Things.
02-19-2023 03:31 PM in
Galaxy SI think it would be much better to have "Device Control" to work with 3rd party apps beyond just SmartThings and Google Home... Because using Devices Control to select SmartThings to run Alexa to activate a Voice Command, it's more than a 3 steps processes... plus voice command is super slow...
I personally not a fan of the alexa app myself. Not able to add Alexa into the Device Control panel apps menu is not a deal breaker for me yet. I think it's a must have feature for the future to allow 3rd party apps to work.
02-19-2023 03:42 PM in
Galaxy SAre you using Samsung's voice engine or Google's?
Google voice works much better for me than Samsung's.
02-19-2023 04:04 PM in
Galaxy SHowever, I'm not a fan for voice command. So slow... I don't even use Google Assistant. Lol
- « Previous
- 1
- 2
- Next »
