07-29-2017 02:30 AM (Last edited 03-14-2019 04:54 AM ) in
Galaxy SThis guide is strictly experimental use only for those users who would like to get their hands on Bixby right now so anything you do, do it at your own risk. You might end up damaging your phone if you dont take care while flashing.
Problems using US firmware are
No Samsung member app. Even if you manage to get app on your phone, it will only show Samsung support and diagnostics but no Community and rewards.
Samsung pay is American app and it will show all American rewards which cannot be redeemed by Canadian resident. I am not even sure if you’ll be able to add Canadian card (I don’t have CIBC card so couldn’t test)
I cannot be sure if future updates from T-Mobile may or may not cause any problem on your Canadian phone. However you can always return back to your original firmware using Smart Switch or Odin 3.
There may be other problems as well that I haven’t tested because I don’t use them.
1) Things you’ll need is
T-Mobile firmware
https://www.androidfilehost.com/?fid=673368273298962140
Odin 3
https://www.androidfilehost.com/?fid=24591023225177749
2) Prepare your phone.
First of all flashing firmware is going to wipe all your data from your phone so backup everything on your phone by any means you use. I used Samsung Smart Switch app for Windows 10. I also backup my phone on my Samsung account and Google account. Don’t forget WhatsApp chat history if you care about your chat.
You will need to download Firmware and Odin from above mention links. When done downloading, extract to their folders (I used WinRAR).
When you connect your phone to Odin, it has to be in Download Mode try following steps
Unplug from USB and turn off your phone than hold volume down key, Bixby key and power button together to start your phone in download mode. Screen will show you message telling you to press volume up key to enter download mode or press volume down key to restart. You have to press volume up to enter download mode.
3) Run Odin 3 in admin mode.
You’ll have to add 4 files to Odin 3 from Firmware extracted folder file names are as follows
Odin 3 AP button >>>AP_G955USQU1AQEF_CL11449429_QB13672995_REV00_user_low_ship_MULTI_CERT_meta.tar
Odin 3 BL button >>>BL_G955USQU1AQEF_CL11449429_QB13672995_REV00_user_low_ship_MULTI_CERT.tar
Odin 3 CP button >>>CP_G955USQU1AQEF_CP6552475_CL11449429_QB13672995_REV00_user_low_ship_MULTI_CERT.tar
Odin 3 CSC button >>> CSC_OYN_G955UOYN1AQEF_CL11449429_QB13672995_REV00_user_low_ship_MULTI_CERT.tar
Other 2 files doesn’t apply anywhere which are userdata and home_CSC so don’t add them to Odin anywhere.
4) Flashing firmware
If your Phone is on Download mode, just press start and let Odin 3 do the work. When finished, phone will automatically restart and Odin will show pass. (Phone will take more than normal time to start)
When your phone starts and initial setup is finished, it will be on US firmware and Bixby should work, you can bring her up by press and holding Bixby key. If you backup your phone with Samsung or Google account, make sure you restore your data during setup. If you use smart switch, finish the setup and then run restore from smart switch PC app.
5) Reverting your phone back to original setting
To go back to Canadian Firmware anytime, download Your Carrier Specific Firmware from https://www.sammobile.com/firmwares/galaxy-s8/SM-G955W/ and repeat steps 2 – 4.
Installing Smart Switch will also install USB drivers require if you don't have it already
Smart Switch for PC
http://www.samsung.com/us/assets/Smart_Switch_pc_setup.exe
Smart Switch for mac
http://www.samsung.com/global/download/smartswitchmac/
- « Previous
- 1
- 2
- Next »
08-04-2017 01:37 PM in
Galaxy S- Mark as New
08-02-2017 08:28 PM in
08-02-2017 08:38 PM in
Galaxy Suse this link on browser. These link will open this post on your browser.
08-02-2017 08:47 PM in
08-04-2017 01:43 PM in
08-04-2017 01:54 PM in
08-04-2017 02:16 PM in
08-04-2017 02:17 PM in
08-04-2017 05:05 PM in
Galaxy S-Nick
- « Previous
- 1
- 2
- Next »
