Help with Bluetooth audio connection.
(Topic created on: 08-18-2017 11:39 AM)
Makthai420
I have a Logitech Bluetooth device connected to my home audio center. Whenever I come home my phone automatically switches me from my phone's audio through this Bluetooth device. It also does it periodically through the day while I'm at home. How can I stop this from happening?
I only want to connect to this Bluetooth device when I choose, not automatically.
3 REPLIES 3
Echo1
Expert Level 4
I honestly don't think you can stop it.... If it's paired and you have Bluetooth on and the Bluetooth device is on it will automatically connect..
The only way I can see a way is to umpair and then when you want to use it pair again as it will still he in your list just unpaired...
Jonathan34
If you download the IFTTT application you can select a location based trigger. Essentially the statement would be If I reach home then disable Bluetooth. And then you can choose to turn on Bluetooth manually yourself when you want to use Bluetooth in your house.
Kobs1406
@Makthai420 Similar to what @Jonathan34 said IFTTT has multiple soultions to this. Just look through bluetooth related Applets.
