is there a way to add data toggle into drop down on pie for s9+?
(Topic created on: 02-07-2019 04:58 AM)
biggz
Really neeed data toggle for my Canadian s9+ in drop down toggle
10 REPLIES 10
Yup adb commands - It's been asked & answered countless times - Just search for "Mobile Data Toggle" & you'll find a couple of ways to use adb 🐧
biggz
ok thanks, seeing that this is pie and its new, so i never searched just asked
No worries - Exactly the same process as on Oreo - Just enable USB Debugging by clicking on the Build Number 7 times & Same as always to enable the Data Toggle.
carr0498
tested with pie - https://community.samsungmembers.com/en_CA/post?postId=208326
biggz
is there a way without a pc? i have none at this time
Nope
biggz
okay thanks y'all
FrankNote10P
didnt worked for me on my note 9 with the script (auto) but worked Well with the tutorial from @ShaggyskunkS9P ... typed adb command and reboot... et voila
biggz
okay thanks
