Loud and annoying chime sounds when checking phone messages.
(Topic created on: 12-04-2022 07:23 AM)
Yijing
How do I disable the extremely loud chime sounds associated with checking my voicemail? They literally hurt my ears.
8 REPLIES 8
Helenna
Hi, are you facing this issue when you receive notification from your messages app?
We kindly request you to write back to us with the detailed description of the issue to assist you better.
Yijing
The problem may be with my service provider. It only occurs when I check my voicemail.
RedDogRabbit
When you receive a Notification that you have a VM, or when you are accessing your VM?
You can check in Settings > Notifications if it is the Notification & change the Notification Sound there.
If it's when you're accessing your VM, you can adjust the System Notification volume down.
Yijing
When accessing
Yijing
Thanks, I'll try that.
Yijing
I think it is my service provider.
RedDogRabbit
Which Carrier are you with?
I'm with Rogers, and when I check my VM, it's just a recorded voice, quietly saying "Welcome to Rogers Voice Mail, please enter your PIN".
Yijing
Fido. I press and hold 1 and I get an extremely loud chime and then a much quiter voice that says, 'who's calling please'. The same chime occurs several times before I can get to my messages. I think they intended to be cute but forgot to turn the volume down on their end.
