Quick panel issue
(Topic created on: 12-22-2023 11:13 AM)
ivanchow4
Using a S23 Ultra
My extended quick panel keeps going back to its default.
I edited the icons to my liking but after a while it resets to the default. Any solution to this.
16 REPLIES 16
BondGirl
I'm unfortunately OCD so all my apps are in folders. No quick panel needed.1703279983279.jpg
RedDogRabbit
Well, there's some things that can't really be added to folders on your desktop.
ie: Rotation, WiFi, Cell Data, Do Not Disturb, etc.
ivanchow4
Seems fine now after i wiped the cache partition
RedDogRabbit
Still strange. Wiping Cache essentially contains temporary files, or fragments of files that don't belong to anything in particular.
Immediately after Wiping Cache, it gets rebuilt as you open apps & operate the phone.
I'm still not sure what could have caused your issue? If Wiping Cache solved it then great, I'm a bit surprised that anything that was in your device's Cache could have caused the problem?
RobertZ
That's how's they get performance out of the OS, but it creates far too many bugs.
BondGirl
Never had that happen on my S22???
RedDogRabbit
I've never had it happen on any device - Ever!
