S23U UI 6.0 Yellow screen help
(Topic created on: 12-13-2023 07:39 PM)
MJCF11
Updated to UI 6 this evening and when I went back to my phone the screen was yellow. Eye comfort shield is off. Changing the color temperature does not correct it. I want my white screen back! Has anyone else had this issue after the update?
UPDATE: colors changed back to normal at sunrise! But I never had dark mode on..could there be another app triggering dark more to turn on? Thanks!
18 Comments
GG2
Expert Level 3
Yellow screen and dark mode are two different things. Even though it's turned off, check in eye comfort shield settings if its set to adaptive instead of custom. Weird things can happen during an update.
MJCF11
MJCF11
With the sun setting so early I really don't want to be looking at a yellow screen from 4pm
Smily78
After downloading the last update my screen turn grey, Samsung 22ultra. I couldn't figure out to reset to the previous update. Please advise if there a way to fix this issue.
RedDogRabbit
Go to Settings > Display & Click on Vivid, you can change the colour tint here, and you can also Click on "Advanced" for more colour settings.
Smily78
Thanks you. It didn't work on that setting However, I managed to change it from wallpaper settings.
RedDogRabbit
That's from using Colour Palette.
Smily78
Yes.
RedDogRabbit
Yes, that wasn't a question 😉
