S7 Edge Downloading mode -
(Topic created on: 11-18-2020 02:33 PM)
MRJ1
My phone is showing Downloading mode for 2 weeks now. Tried rebooting by pressing volume up + power+ home buttons which did not work and then tried with volume down + home+power button. Nothing seems to work. Also noticed that there are no message lines on the upper left side of the screen (saw that its there on other phones stuck in this mode , on youtube).
Took it to Casemogul, but they weren't helpful - no explanation from them.
Any one knows what does this mean for my phone?
4 Comments
Halston
Hi MRJ1,
Your device needs to be get examined and repaired by the authorized technician. Please contact the live chat support so that they will help you accordingly.
Here is the link: https://www.samsung.com/ca/livechat
mytech
Expert Level 3
I'd try this backflip first
@Cassidy
https://r1.community.samsung.com/t5/others/wipe-cache-partition-for-all-devices-en-fr/td-p/3156063
If that don't get you into the circus then I would backup my device with smartswitch to a computer and/or cloud it all then factory reset device, this may get you hired for the next show 🤪👍
RobertZ
If you get the download mode screen, you could also try plugging the phone into a computer running SmartSwitch. The app has the ability to do an "emergency" firmware restore it it detects the phone in download mode, and that may resolve the issue.
qhy232
Beginner Level 4
I want to say this is the EXACT same problem I'm having with my S7 edge (ESP. the "no msg on upper left screen" part).
And I also tried everything mentioned in here and other places like below, but no luck.
https://appuals.com/fix-downloading-not-turn-off-target/
And all I did was leaving my phone in my car for a whole night (also in last Nov so it must be cold) and it has been giving me this screen/error ever since (I did not do any rom flash or upgrade whatsoever).
What I'm wondering is if Samsung pushed an update package at that night and my phone just automatically chose to perform a system upgrade and it never got to finish because my battery died in the middle of the process?
BTW smart switch gave an error when I connect the phone with this "downloading" mode, and when it's powered off, it won't connect at all.
