Samsung S21 Vs S21 Ultra battery life
(Topic created on: 09-06-2021 03:34 PM)
john-92
Hi everyone,  just want to ask if the s21 ultra battery life is far more better to regular s21 in real life usage. Planning to upgrade from s20. Thanks
15 Comments
KOTS21
I can speak for the 21 ultra my day starts at 6am with everything basically on max except for my screen brightness it's usually at half and using dark mode. 16 hours later  with 7 to 8 hours screen on time, notifications,texts, calls and about 3 hours using YouTube music. You can't go wrong with this phone. I don't play games and use social media sparingly. Camera is A1 and the phone is very fast.
john-92
Are you using wifi or mobile data?
KOTS21
  • I would say 70% wifi 30% data.
john-92
Okay tnx a lot from your response. I think this is really a good mobile.
KOTS21
You won't regret it
Just a note that there will no SD card slot on S21 or S21 Ultra.
john-92
Thanks for the heads-up
soccerdad
Thanks, it's something that I am considering also!
I own the S21 Ultra and find that the battery life lasts a lot longer than my previous phone which was the S9. On the S9, if the battery was completely full, the use I was giving the phone, the battery would be down to approximately 30% by the end of the day. I charged my S21 Ultra completely, gave the phone a lot of use today and now my battery is down from 100% to 60%.
