aldel99
04-10-2021 01:58 PM in
Hi
I have 2 SD cards (samsung evo plus 256gb & 512gb) running on my S20 and Note 10+.
The advertised speed of the cards is 100 read / 90 write.
I did a couple of benchmarks and the speeds are considerably less on my phones. About 70 read and 50 write.
Is this a limitation of the phone? I bought the cards from Best Buy so I'm pretty certain they aren't knockoffs. I also had a SanDisk extreme plus in there before with advertised speeds of 170 read and 90 write and that didn't do well either in testing.
I used A1 SD BENCH and did Accurate testing (with reboot).
4 REPLIES 4
Vic20
04-10-2021 05:06 PM in
Usually hardware related. The cards (like everything else) will state theoretical speeds. It's not guaranteed... Why it's always advertised/stated as 'up to'.
Cassidy
04-11-2021 06:32 AM (Last edited 04-11-2021 06:36 AM ) in
Galaxy SI invite you to read this article to understand how it works..
https://r1.community.samsung.com/t5/others/all-about-sd-cards/m-p/2941101#M19683
If you don't have U3 V60 or more, it will give you good speed
don't expect too much on U1 class 10 card
aldel99
04-12-2021 03:56 PM in
So I did se testing...
I put all 3 sd cards on my SD card reader and connected to computer. Formatted and tested with CrystalDiskMark with default settings.
All 3 cards had almost identical results for sequential read and write.
90-95 read
80-85 write
I put them back in my phones and it was back to about 75 read and 50 write
I also tried formatting the cards on my phone and not enabling encryption (I know theoretically it should make no difference but I thought I'd try it) and it made no difference
90-95 read
80-85 write
