slow battery charging
(Topic created on: 08-23-2018 10:18 AM)
jinca
1.5 year old s7 edge...
battery has been charging almost 7 hours now but still 88% full without using while charging.
6 Comments
If you're using the OEM USB cable & charging block & It's still not charging beyond 88% I'd try a couple of things - Reboot to Recovery & Wipe Cache - Reboot and see if it charges up to 100% - If not - You could Boot into Safe Mode & See if it charges to 100% - If not - Run the Diagnostic test available here on the Samsung Members app - Depending on the result - It might be time to go a Samsung Service Center 🐧
https://www.samsung.com/ca/support/service-center/
carr0498
sounds to me like the battery is failing
Yeah that's what I'm thinking... but it seems kinda soon for the battery to be failing.. The original battery in my Note 2 & 3 still take a full charge I think even my skyrocket does....
carr0498
defects happen randomly unfortunately
Yeah I know - My Note 4 has the emmc issue...
Moderator_
Hi @jinca,
First I would check that its not a problem with your charging cable, maybe try using another cable if you have one handy. If this does not work please contact your local Samsung Service Center (http://www.samsung.com/ca/support/servicelocation/) for support.
-Jenna
