[SOLVED] Advanced Messaging (RCS) not working on Bell
(Topic created on: 05-27-2018 01:42 PM)
Dilbert
I have an S8 Plus and my wife has the S9 Plus, and we're both on the Bell network.
According to the Bell website, both these phones are compatible with Bell's Advanced Messaging (RCS) services.
However, the messages sent using the default Samsung Messages app are still being sent as standard SMS/MMS texts. This happens even after I force the message styles to "Chat" in settings. According to the Bell website, both of these phones should default to the RCS.
Any ideas why Advanced Messaging is not working?
17 REPLIES 17
kev15
are you on LTE+?
Dilbert
Yes I am...I'm in the Montreal area that has complete LTE-A coverage from Bell
kev15
Ok donc essayer de restaurer par défaut les valeurs réseau et l'apn et redémarrer vos téléphone jai eux le même problème
Dilbert
Thanks for the suggestion, but unfortunately, still no luck. I'll try to see if Bell tech support has a solution...🤞
brownbatman
Have you made sure both phones are up to date on software updates?
Dilbert
Yes, both are on Oreo
brownbatman
Did you buy both phones from bell?
Dilbert
Yes I did. According to the website below, Advanced Messaging is automatically enabled on both the S8 Plus and the S9 Plus.
https://support.bell.ca/mobility/rate_plans_features/how_to_use_advanced_messaging?step=2#step2
it does not work on my phone, I am also with Bell but got my S9 from Samsung...so that could be why.
I sorta just gave up.
