Resolved! Solved
Smart lock [Possible Solution]
(Topic created on: 09-22-2023 03:57 PM)
RedDogRabbit
Others
Go to Settings > Apps & Search for Play Services > Select it & Scroll down to Storage > Clear Both Cache & Data for Play Services & Reboot.
Trusted Devices is there once again.
It's not a Samsung issue, it's a Google Play Services issue.
Also check the version of Play Services installed on your device.
You can Force a Play Services update by Clicking on "Uninstall Updates" & Rebooting your device.
This is Play Services version installed on my device.
2 Solutions
Ray1
Expert Level 3
Others
Your solution worked for me to get the option to add a trusted device back on my phone but then will not let me add my watch back as a trusted device.
Routines works in the mean time
Ray1
Expert Level 3
Others
Strange - I never had my watch connected to take calls but after I did that it was accepted as a device to keep my phone unlocked.🤔😂
5 REPLIES 5
Ray1
Expert Level 3
Others
RedDogRabbit
Others
Weird
I had no trouble adding my 2 "trusted devices", and neither of them are Samsung devices. 🤔
Ray1
Expert Level 3
Others
NewToSamsung
Others
Worked for me. Now to delete the routines I created and see how long the Trusted devices stays.
Helenna
Others
Hi, we are happy for you and thank you for sharing the information with our Community members.
