Setting problems on the s10e (please help me)
(Topic created on: 03-25-2019 09:49 AM)
bMike10e
Smartthings
I can't access the Device Care settings. When I press the 3 dots on the top right corner other words come up.
9 REPLIES 9
iFlYSoLo
Smartthings
Try to wipe the cache partition and reboot and then try again. clearing cache fixes most issues. instructions in video below.
bMike10e
Smartthings
I'll try that, thank you for the help
iFlYSoLo
Smartthings
bMike10e
Smartthings
sully
Smartthings
hey @bMike. can you please post a screenshot displaying what comes up
Echo1
Expert Level 4
Smartthings
Device Care/Maintenance is in your settings about 2/3 down....
please see attached Screen shot
bMike10e
Smartthings
@Echo1 I know where its located, but I having problem with the settings in device care; usually it would show settings when you press on the 3 dots on the top right. however my phone is showing different settings.
Echo1
Expert Level 4
Smartthings
with you now... will look into it and get back to you..
Smartthings
Hi bMike10e, the picture you attached is the settings menu that you says is different? I screenshot mine and I do not see the difference. Just curious what is not the same...🤔
