Review for Samsung Galaxy fit 4
(Topic created on: 12-16-2024 03:46 PM)
Alzoe
Wearables
I’ve been using the Galaxy Fit 3 for a while, and overall, it’s a great fitness tracker for its price. However, there’s one issue that doesn’t make sense to me: it supports the Step Machine activity but not the Stair Climber, even though both involve almost identical movements. The Step Machine mode works perfectly, so the device clearly has the capability to track this type of vertical movement. Why exclude Stair Climber, which is just as common and uses the same motion? This feels like an arbitrary limitation, especially considering how versatile Samsung Health is. I strongly recommend adding support for Stair Climber in a future update. It would make the device much more appealing to users who rely on this popular form of exercise. The hardware is clearly capable, so this is likely a software issue that could easily be addressed. Please listen to your users and consider adding this feature!
Helenna
Wearables
Hi Alzoe,
We will definitely consider this as a valuable feedback and bring this to our team for review. Hopefully, the Stair Climber support will be added in future updates.
Thank you for sharing the constructive suggestions with us.
