A53 wifi connection problem.
(Topic created on: 05-16-2023 05:54 AM)
Polarmik
Trying to connect to wifi, does not connect with address and password that was copied from S9. Cannot delete to try with new password.
Looking for help, thanks. Phone is A53.
3 REPLIES 3
If you go to Settings -> Connections -> Wi-Fi -> gear icon on far right.
You can forget the network and re-enter the new password after.Screenshot_20230516_073701_Settings.jpg
Polarmik
Thanks, I did try that. I believe the address was changed slightly, like maybe removed caps, not sure. I'm trying to just delete and start over, but A53 will not allow.
Helenna
Hi, you can also perform Reset Network settings on the device and check for the issue.
Go to Settings, and then select General management >> Find and select Reset >> Choose Reset network settings >> Tap on the Reset settings button >> Tap on the Reset button.
Note: When you reset the network settings, the Wi-Fi and Bluetooth information connection are reset.
