Browsers using abnormal amount of battery
(Topic created on: 04-10-2019 08:42 AM)
dmflash
Galaxy Note
Since updating to Pie
I've noticed browsers using way more battery than before. I've tried switching different browsers but it makes no difference.  Is anyone else experiencing this?
23 REPLIES 23
theonecid
Galaxy Note
That's not even the real Samsung Internet icon. Are you sure that's the real browser and not some third party application?
dmflash
Galaxy Note
I'm using a theme
theonecid
Galaxy Note
Got it. What version of the browser is it?
awesomeness
Galaxy Note
Well... That's interesting. As always, I recommend first off, that you restart your phone. The issue could be with the battery, as those ratings aren't always accurate. Try clearing the app cache by going into settings > apps > Samsung internet > storage > clear cache. You can also try using power saving mode, but that does seem like a fair amount of usage for 2 hours. Make sure your screen brightness also isn't up too high, that's the biggest problem usually with battery drainage.
dmflash
Galaxy Note
I tried clearing the app cache yesterday and today I used the option to put the app to sleep automatically when not in use, so I narrowed it down to the fact it's just using lots of juice when using it.
dmflash
Galaxy Note
version 9.2.00.70
theonecid
Galaxy Note
hmm weird. same here and browser is fine
dmflash
Galaxy Note
@theonecid, all browsers I've tried are now battery hogs. I was kinda selfishly hoping it was a wide spread problem so Samsung would put out a fix lol
Galaxy Note
Possibly it's the Samsung Internet add-ons that are draining the battery... 🐧
