display color issue after android 10 with samsung note9 SM-960W based device
(Topic created on: 03-19-2020 08:06 PM)
santhanam
Galaxy Note
Hi, I seem to have a display color issue after the recent android 10 and one UI 2.0 update. Since I was watching a movie on the device just before the update that I was able to immediately notice a display color issue. Theres a oily coat on blacks especially. All the other colors seems to be fine especially greens are brilliant.
I'm trying to find a software based solution either by setting or patches. But service centre just say display replacement as solution.
If I did not notice the difference immediately I myself would have gone for screen replacement thinking it as pixel burn issue or something but since it's not such an issue I am a bit worried as to whether I would receive a solution for this.
Regards
Santhanam
14 REPLIES 14
Galaxy Note
You can adjust the colour here - Settings - Display - Visibility Enhancements or Settings - Search for Video Enhancer.
Jeremie
Galaxy Note
@santhanam,
Yes, you can adjust the display colour as mentioned by @Shaggyskunk1 using the below steps
settings >> accessibility >> visibility enhancements >> colour adjustment
settings >> advance features >> video enhancer
If you are still facing the same issue, please let us know.
santhanam
Galaxy Note
I tried every thing , it doesnt seem to fix
Jeremie
Galaxy Note
@santhanam,
As you have tried the above-mentioned steps, please share the screenshots of the color issue you are facing which helps me to give more information.
santhanam
Galaxy Note
let me try to capture it and send it, I'm not sure if it evident in pics it's only visible is an video.
santhanam
Galaxy Note
this is the issue
Jeremie
Galaxy Note
@santhanam,
I just watched the video that you have mentioned. The background image behind the lady is a slight oily textured when she was focused as you have mentioned, I have noticed the same on my device.
Are you facing this issue with only this video or any other videos?
santhanam
Galaxy Note
I face this issue with other videos too, its evident very much in this video. let me get some other sample of videos and normal vibrancy for other colors
santhanam
Galaxy Note
just look at these screen shots of similar movie scene in the night time. the issue is with only blacks. all the other colors seem to be brilliant than before. since blacks have issue the darker shades have faded oily effect.
