Resolved! Solved
Android System WebView pending more than 1 hours and nothing happens
(Topic created on: 03-23-2021 12:41 PM)
NataTara
i am very frustrated. No mails, no browser, nothing work. I cannot do my job. I am trying to update WebView during 1 h and it is still pending. I am worry that all sensitive information in my cellphone was compromised. It is terrible.
2 Solutions
Cassidy
Go in Settings / apps/your apps/Android system webview and click on the 3dots at the right top of screen and select uninstall updates
This will work
Cassidy
Pictures not in order..hope you understand french
Settings / apps/your apps (system application)/Android system webview and click on the 3dots at the right top of screen and select uninstall updates
6 REPLIES 6
Cassidy
This will work
NataTara
Thank you very much. It works. I hope that android and Samsung  would not create more problem for customers. It is very frustrated.
Pupusik
Great work as always 😀
Try restart your phone and update again.
NataTara
Does not work. Still is pending
Cassidy
