Bermersher
08-19-2019 06:47 AM in
Seems like with several different third party devices, Bluetooth audio on the S10 Plus creates a crackling, distortion noise accompanying high pitches in audio. Is this just me?
4 REPLIES 4
Bermersher
08-19-2019 07:42 AM in
I have tried that twice, and I have tried factory reset as well. I had the same problem with my Galaxy S8 when I had that, but not with an LG G6 or a Galaxy A5 on the same Bluetooth devices.
tiparacha
08-19-2019 07:52 AM in
I have Galaxy S10 and I have started getting Bluetooth audio issues since the latest software update. Most audio problems are with Whatsapp media and calls.
Shaggyskunk1BLM
08-19-2019 08:08 AM (Last edited 08-19-2019 09:35 AM ) in
I don't use WhatsApp & Calls with either Sennheiser Momentum wireless or Jabra elite active are crystal clear on both sides of the call - It MAY be an issue with the Bluetooth devices being used - Especially as you have Reset the Network & Factory Reset your device.. 🐧
jiggles
08-19-2019 08:30 AM in
I didn't know that these apps even existed. I always used WhatsApp, gotta check them out ☺️
