connection issues
(Topic created on: 05-05-2016 05:38 PM)
ecliff
anyone else have problems staying connected to either data or WiFi? had the same problem on my s6 after the marshmallow update
9 REPLIES 9
KimmiCo
Beginner Level 3
I am...it's annoying....it's have only had my phone 3 days
ecliff
I thought the problem would go away with the new phone but nope
Bradsteff
yes it's getting better but several times I've almost brought the phone back. Every review says the new S7 is so awesome ... there are still a lot of bugs to work through!!
ecliff
s6 with marshmallow is a paper weight my husband can't use it at all Samsung is blaming Google sasktel is blaming Samsung and the damn phone doesn't work
traceylynne
I'm having this issue consistently everyday. I've had my phone since April 2016
StormRunner
Wi-fi has worked very well for me and I connect to a Wind wi-fi stick. I may be the only person without a complaint about Wind though. lol
deny03
I started noticing my phone losing wifi connecting. everytime I check the wifi on the phone it reconnects. but then after a while it loses connection again. frustrating I always end up maxing out my cell data.
dar
WiFi connection is a problem for certain apps since update. such as Facebook newsfeed not current and playmusic not allowing me to listen to stations. never had these issues before the software update a few days ago. I don't like the new format and changes and really frustrating that I'm having issues with my WiFi now
white1
I got my phone 2 months ago and I too have the same wifi issues. Everytime I check the wifi is off. It's killing my data plan. If anyone can help please.....
