S24 FE Car Connection Issue
(Topic created on: 12-11-2024 01:57 PM)
Jimmy_Tos
Issues having the audio and android auto functions work with between S24 FE and 2024 brand new vehicle. There were no issues with S20 or even an S23 working with the car. What kind of solution is there for this issue, Samsung!? Is this an Android Auto update that is required or one with the phone's specific software.
5 REPLIES 5
Not applicable
I don't think so
Ray1
Expert Level 3
Try disconnecting your device and reconnecting for audio issues
S24s are quite temperamental with Android Auto
You could try going to Settings, Apps, Android Auto, Storage and clear Data and then restart your phone.
You will have to set up Android Auto again on your phone but it usually gets it working - I have had this happen numerous times
Helenna
Hi Jimmy_Tos,
The issue you're experiencing with the Galaxy S24 FE and Android Auto in your 2024 vehicle is likely related to compatibility or software differences between the devices.
As suggested by Ray1, please try disconnecting and reconnecting your device and also perform Clear Cache and Data for Android Auto:
Go to Settings > Apps > Android Auto > Storage > Clear Cache and Clear Data. Then reconnect your phone to the car.
Reset Android Auto Connection: Delete the car from Android Auto's device list (Android Auto > Settings > Connected cars > Forget this car) and reconnect it from scratch.
Thank you.
dodgelofa
If you're experiencing connection issues with your S24 FE car, it could be due to underlying engine problems affecting performance. One potential culprit could be a faulty catalytic converter, which impacts exhaust efficiency. If you notice unusual engine noises or decreased performance, Car Catalytic Converter Repair might be necessary to restore your vehicle’s functionality and prevent further damage.
joldenhire
When dealing with something like the S24 FE car connection issue, it’s a reminder that even small technical problems can be frustrating and disrupt your day. Cars are the same one minor fault, especially a weak or dying battery, can suddenly leave you stuck. That’s why having access to Varta battery installation and replacement in Abu Dhabi is so helpful for drivers who want dependable support without delays. It ensures your car stays ready to go, even when unexpected issues pop up.
