help with symbols
(Topic created on: 05-15-2018 04:24 PM)
Zeoswj
what does the circle with a diagonal line through it on the top right do and how do I get rid of it. The circle on the left is the do not disturb... helpdcf8dcc4-ee0d-4e6c-a33a-7fd0daee9d43.jpg
13 REPLIES 13
It COULD be an issue with the SIM card itself - OR the SIM card slot? Contact your Carrier and ask them to GIVE you a a replacement SIM card & see if it resolves the issue - If it doesn't then I'd guess that it could be an issue with the SIM card slot? Anyway a quick way to rule things out would be by starting with a new SIM (they can fail but still kinda work) 🐧
carr0498
+1 - start with the sim card. it is indeed the icon for "no cellular signal"
Zeoswj
thank you all so much for your help. this is a awesome group. I will contact my carrier
Moderator_
Hey @Zeoswj, we are sorry to hear your experience with our device. If your issue does not get solved after contacting your carrier, please contact your local Samsung Service Center (http://www.samsung.com/ca/support/servicelocation/). Thanks!
- Wonchul
