Resolved! Solved
Is it normal for my S24 Ultra to get warm - a little bit hot?
(Topic created on: 01-10-2025 09:19 AM)
GregD1999
Beginner Level 3
I been noticing it lately. I have taken my phone case off.
Has anyone has this problem?
I was plugged in and typing an email and my phone got a bit warmer, and temp went down as soon as I left it to charge. so like RDR said, its normal based on the tasks you are performing.
10 Comments
Mehxkdeep
Yes, i have been noticing this lately as well. Maybe samsung will fix this issue in jan patch, or maybe they doing it on purposely for us to buy s25.
RedDogRabbit
Depending on what you are doing with any mobile device, it is perfectly normal to notice a fluctuation in the device's temperature.
The notion that Samsung, would deliberately do something detrimental to the device is preposterous.
SgtStubby
Your joking right?
SgtStubby
Right? Why do I have these thoughts every time a new device launches? My S23U is working great and honeslty I don't want to get disappointed by a new more expensive device that isn't really any better than what I already have. In fact some of these have less options. Apperantly the S25 S pen no longer has blue tooth so that's a big downgrade.
Helenna
Hi GregD1999,
Yes, RedDogRabbit is right! Temperature fluctuations are a natural aspect of using any powerful device like the Galaxy S24 Ultra. Samsung devices are designed to handle increased temperatures during demanding tasks like gaming, video streaming, or multitasking. If a device gets slightly warm or hot during normal use, it’s usually within safe operating limits.
Thank you.
Goldenseal
You can use this official Samsung app called Thermal Guardian in the Good Guardians app to track your phone's temperature and see if it fluctuates too much. It's not avaliable in the Canada Galaxy Store, but you can download it from APKMiiror. 😊1736547888336.jpg
Sonofsam
Happens to me when my phone is watching Baywatch.
SgtStubby
My friend calls that show CROTCHWATCH
GregD1999
Beginner Level 3
Thanks everyone.🙂
