Modes and routines won't work
(Topic created on: 11-11-2023 04:24 AM)
urikazoo
I have a Galaxy S21 FE, with the most updated system update (One UI 5.1)
I'm trying to create a mode where I won't get any notifications except few ones I'm choosing, and it just won't work.
I wand the all the apps to keep working, without the notifications (accept the few ones I choose to keep notifications on).
in the mode settings I go to -> do not disturb -> app notifiactions -> I'm allowing only certain apps to get notifications from.
Once the mode is activated, I'm still getting all notifications from all apps.
I've tried rebooting the phone, deleting the cache and data of the Digital Wellbeing app, as well as checking it's not under any battery battery saving lists.
None of the above fixed the issue.
Would love to get some help on this one.
Thank you!
2 REPLIES 2
RedDogRabbit
Why don't you just go to Settings >  Notifications and "All" "Most Frequent" or "Most Recent", and Toggle Off Notifications for the apps you don't want any Notifications from?
Easier than Modes & Routines.
Helenna
Hi, as adviced by RedDogRabbit have you tried the steps to stop the "Notification."
Is your issue resolved ?
