No sound
(Topic created on: 04-22-2025 08:48 PM)
Jaybird11
Alright community, I have a huge problem here lol. All of a sudden my speakers on phone do not play sound. Can't make or receive phone calls. Can't watch videos across all platforms. Can't listen to music on Spotify
Please help me community
TIA
6 Comments
RedDogRabbit
What device do you have?
Start with opening the Samsung Members app on your device & click on Support > Phone Diagnostics & run the Diagnostics for your device.. see if you get any error messages.
Power Off & Remove & Reinsert the SIM (if you're using a physical SIM).
Boot into Recovery & Wipe Cache.
If the situation remains the same, you can try Booting into Safe Mode, see if you can make calls..
If not, I'd backup with Smart Switch & Factory Reset.
Don't restore ANYTHING initially, see if you can use your phone & if audio is working.
If nothing works.. visit a Samsung Service Centre to get it checked out by a tech.
https://www.samsung.com/ca/support/service-center/
Jaybird11
S21 ultra. Thanks, I'll give these a try
RedDogRabbit
Good luck, hopefully it isn't a hardware issue 🤞🏻
Jaybird11
Well, I've tried them all, same result. Plus, I can't even reboot into recovery mode to wipe cache. I think she's cooked 😥
Jaybird11
Update: I'm an *** and forgot to realize that phone needed to be off to reboot haha. But same result. Still nothing. I appreciate your help!
Helenna
Hi Jaybird11,
We understand how frustrating it must be to lose all audio on your device. Please try the troubleshooting steps provided by RedDogRabbit and let us know how it goes.
If none of the steps work, we recommend visiting a Samsung Authorized Service Center to have your device checked by a technician. Please use link given to know the nearest Samsung Authorized service center.
Thank you.
