S20 FE fingerprint scanner issue
(Topic created on: 04-18-2022 06:09 AM)
JDelii
Not really sure whats happening but lately my fingerprint scanner sometimes doesn't wanna work from the AOD.
its random but sometimes when i try to scan my print the screen dims and it won't scan. Just keeps saying to press longer. Even if i hold my finger there. How can i fix this?
17 REPLIES 17
RedDogRabbit
Good to hear, but AOD really shouldn't have any effect on the Ultrasonic Finger Print Scanner.. it's more likely to be a coincidence that it's working okay now, more likely that the other suggestions are what actually resulted in any improvement. 👍
Mvanderhoof
I'm having the same exact issue. Started this morning last software update was 2 days ago.
Things done already
No screen protector.
Restarted
Rebooted
Wiped partition cache; rebooted
Removed stored fingerprints
Cleaned screen, cleaned thumbs
Tried diagnostic under Samsung Members app- doesn't work because the diagnostic tool can't read my finger print!
Result:
Now cannot register new fingerprints- same error "Press a little longer".
It's like the scanner times out after 1 seconds.
None of the presented solutions works. Hoping a Lvl 5 expert has some other tricks.
Thanks!
Meyercw
Did you eventually get your problem sorted? I'm sitting with exact same challenge.
Helenna
Hi, That's good to hear that your issue is fixed.
Please get back to us if you require any further assistance.
Mvanderhoof
I have the exact same issue. None of the previously provided solutions has worked.
Cannot set up new print or diagnosis because print scanner continues to error "Press a little longer". It's like the scanner is timing out.
Thoughts?
Meettya
Beginner Level 3
Same case here, at the some time - I suppose after update.
I try every solutions, except full wipe of - nothing worked, just "Press a little longer" at register or test suite.
In my opinion its software problem.
Gabriel-001
Hi all,
I had faced with the same problem as well. The error was just asking me to place my fingerprint longer.
But is just won't work, I try to reset all setting (not factory setting) still won't work & can't register new fingerprint now.
@JDelii may we know what you try on the AlwaysOnDisplay make it work again?
Thank you!
Applebottom69
I had this same problem so I made a bunch of changes in setting and now it's working fine i guess. If u still face the issue my method might help.
Open settings > Apps (select show all system apps from the top right corner)
> Search biometrics and open the app
In the biometrics app:
Step-1> Storage > clear cache
Step-2> battery > select unrestricted access
(Do both these steps)
Now turn off power saving mode and reboot the device.
This method worked for me hope this helps u guys to<3
