S24 Ultra Battery Bug
(Topic created on: 05-13-2025 07:45 AM)
Sid3030
I purchased my new Galaxy S24 Ultra in December 2024. For the past two weeks since updating to OneUI 7.0, I have experienced persistent battery problems. Initially, the battery drained rapidly; however, for the past week, the phone has unexpectedly shut down, displaying 0% battery, even after charging to 100% or more than 50%. My daily screen usage is a maximum of three hours. Please advise on resolving this issue; it is causing significant concern and is not the expected performance for this device.
4 Comments
Ray1
There have been a lot of posts about battery drain problems since updating to One UI 7.
Hopefully Samsung will be pushing out an update soon to help with the problem
In the mean time have a look at this post that has suggestions on helping to fix problems after updating
https://r1.community.samsung.com/t5/others/best-practices-after-one-ui-android-version-update/td-p/3...
Helenna
Hi Sid3030,
We're sorry to hear about the unexpected battery drain and shutdowns you're encountering.
To help address this, we recommend reviewing and following the steps outlined in the link given above by Ray1.
Please go through the suggestions carefully, and monitor your device's behavior afterward. If the issue persists even after applying the recommended steps, feel free to update us here or run a battery diagnostics test through the Samsung Members app under Support > Phone Diagnostics.
We appreciate your patience and are here to assist further if needed.
Thank you.
Sid3030
I have performed this action repeatedly, yet no results are apparent.
Jonathan5675
Weird, as an S24u user, my battery has been about the same, pretty good
