09-11-2021 07:33 AM in
09-11-2021 08:04 AM in
Galaxy SHi Vleadz, I suggest you to remove any cases, skins, or protectors from your phone. They could be blocking the wireless signal.
If headphones are connected to your phone, it could block the phone from charging. Disconnect the headphones or place your phone in a landscape position. Do not use your phone while it is wirelessly charging.
If a charger or USB cable is connected to your phone, the wireless charging feature may be unavailable. Disconnect any cables from the phone's USB port.
09-11-2021 08:41 AM in
Galaxy SNothing connected. Bluetooth and NFC disabled. No USB-C connected. Not using the phone.
09-11-2021 09:19 AM in
Galaxy SDid you try Rebooting the phone?
I've seen this happen before with USB cable charging & a Reboot resolved the issue.
09-11-2021 09:38 AM in
Galaxy S- Mark as New
09-12-2021 12:47 PM in
09-12-2021 01:50 PM in
Galaxy SRead the post & respond to the questions, Nah, too time consuming lol 😂
09-11-2021 08:12 AM in
Galaxy SAlso, do you have Fast Wireless Charging enable under Battery settings?
09-11-2021 08:45 AM in
Galaxy SYes, tried with that option disabled and enabled.
