Samsung Fridge - Freezer Not Cooling
(Topic created on: 01-13-2019 07:43 PM)
Shawn24
Others
I have seen extensive complaints on the U.S. Samsung site about this issue, but nothing on the Canadian site. That's probably because there isn't a support forum dedicated to refrigerators.
Anyway, I have a 5 year old Samsung fridge RB194ACRS with a freezer that no longer cools. I have verified that the thermistor (sensor) in the freezer is functioning and that the resistance is correct at given temperatures according to Samsung resistance tables. So even though the sensor appears to be functional, if I plug it in and turn on the fridge, the fridge will show that both the fridge and freezer are slowly dropping in temperature to the desired set point.
HOWEVER, only the fridge actually drops in temperature. The freezer does not. Remember, the freezer sensor is functioning, but for some reason the display on the fridge shows the interior of the freezer is at -25 degrees Celsius, when it's actually only 0 degrees Celsius.
Upon viewing the evaporator coil, I note that there is some frosting on only a part of the upper coil. The defrost cycle does work and melts any frosting.
Please advise how a fridge that has not been abused has only lasted 5 years. This appears to be a common issue with Samsung and I would like to know what the fix is.
5 Comments
Echo1
Expert Level 4
Others
Sorry to hear about your troubles but your on s site that mainly covers Samsung mobile devices but I am sure that your post will be read by someone in the Samsung support staff and hopefully they can help you. In the mean time I would recommend that you call Samsung 1-800-726-7824 and ask to be out through to the dept that looks after appliances..
Hope this helps
Steve01
Others
Good morning, thank you for posting and sharing your experience. This community is for all Samsung Products and I appreciate the time you have taken to outline the challenges you are experiencing. I have shared this post with our Support team and they will be in touch with you.
Amit79
Others
What is the outcome because I have the same problem with this model https://www.samsung.com/ca/support/model/RB194ACRS/XAC/
DaveS1
Others
I also have a five year old fridge. It has been a total dud. It has to be manually defrosted every day. Even then, I have to leave it unplugged over night at least one a month to defrost it. The ice maker has been jammed shut with ice build up for the last three years. Now there is water building up under the meat and cheese drawer.
KB1999
Others
I'm not as knowledge as you, @Shawn24, but can say that I have the same issues. This is a known problem that Samsung refuses to solve, beyond providing a wider drain evaporator clip .
Is it the sensor or the computer or a mechanical component? The repair company adds that blow-in insulation could
My freezer is -20 degrees right now with water and ice under the crisper drawer and the crisper is so cold that it's no usable. The drain tube in the back panel is frozen and causing that  – but it's the symptom not the root cause.
It's shocking to me that Samsung has known this for at least the 5 years that I have also had my frig and barely admits there's a problem, let along find a solve.
