Anyone facing battery drain issue in one ui 7?
(Topic created on: 06-22-2025 08:34 PM)
Vignu
Since ui 7 update my battery ***. Any suggestions?
3 REPLIES 3
jamesy
Yeah, Samsung messed up with One ui 7. It is not well optimized. One ui 8 looks promising though
Helenna
Hi Vignu,
We are sorry to hear that your'e experiencing this issue after the update. We have shared similar feedback regarding increased battery drain after updating to One UI 7, and we completely understand how frustrating that can be, especially on a new or previously well-performing device.
We recommend trying the following steps:
Restart your device – Sometimes a simple restart post-update can help stabilize background processes.
Check battery usage under Settings > Battery > Usage since last full charge to identify any apps consuming abnormal power.
Wipe cache partition via Recovery Mode — this helps clean leftover temporary files from the previous version and has been known to resolve post-update battery drain.
Enable Adaptive Battery and limit background activity for non-essential apps
Also, please consider sending an Error Report through the Samsung Members app so our team can review any unusual battery behavior: Samsung Members > Get Help > Send Feedback > Battery.
Thank you.
RedDogRabbit
From what I've seen on Sammobile & SammyFans, the battery drain issue is quite widespread.
Hopefully it will be rectified in the next Update.
