Samsung galaxy s20 ultra Battery life
(Topic created on: 09-24-2022 09:01 PM)
Asif_ca
Beginner Level 5
Hi folks, recently I'm noticing my samsung galaxy s20 ultra's battery goes down very quickly even though its a year old phone. Is anyone facing same problem???
3 Comments
RedDogRabbit
You can start with Opening the Samsung Members app Click on Support & Diagnostics then run the Diagnostics for the Battery to check it's health.
You could also check to see that your apps are being Optimized & limit the background usage of apps that you don't really use.
If it's been a year, backing up your device with Smart Switch & Factory Reset can also improve the battery life during the day.
There's more that you can do, but this should get you started.
Ray1
Before you factory reset you should check by going to Settings, Battery and Device care, Battery and see which apps are using the most of your battery. You can touch different parts of the graph and see which apps are using the most at different parts of the day
Helenna
Hi, please follow the steps provided by others and verify if your battery issue with your Galaxy S20 Ultra is resolved and keep us posted.
Thank you RedDogRabbit and Ray1.
