Battery drain problem in S10
(Topic created on: 03-07-2020 11:30 PM)
cruze007
After the latest software update the battery has started to drain faster. Please fix this issue.
5 Comments
mytech
Expert Level 3
1st answer will likely be this...
https://r1.community.samsung.com/t5/Others/Wipe-cache-partition-for-all-devices/td-p/3156063
2nd answer if that don't work, will be a backup with smartswitch then a factory reset 🤦‍♂️
Sorry I got no links for this @Cassidy is slacking 🤪🙃👍
Cassidy
Bhavik
Please precise , is this after 1- Android and/or security update or After 2-Device Care Update.
1- wipe cache partition
2- If it's after Device Care update , i have solutions here :
I had the same problem, but i resolve it differently, check there
https://r1.community.samsung.com/t5/Galaxy-Note/Device-care-Maintenance-is-killing-my-battery/td-p/3...
Mytech , i know, i know , i let a chance to @makeanimationssmooth to really help people
Kinsley
Hi Bhavik,  your device provides various options that help you conserve battery power. Please try the below suggestions.
• Optimize the device using the device care feature.
• Activate power-saving mode.
• Decrease the backlight time.
• Close unnecessary apps.
• Deactivate the Bluetooth feature when not in use.
• Deactivate auto-syncing of apps that need to be synced.
• Decrease screen brightness.
mytech
Expert Level 3
Omg is my device useable after this 🤦♂️
This s10 is a powerful device and nobody should hafta do this 🤷♂️
Again a tip to all, when it's running well LEAVE IT ALONE! (no updating) that's my motto anyway, to each their own 🤙👍
Btw I have everything on and up and no issues here, I love the fast charging too 🤪 and friend charging, it's like our phones are making out 🤣🤙👍
