Battery Issues
(Topic created on: 03-16-2022 12:32 PM)
AndroidGuy
I am currently using a Galaxy s20 FE 5G, and ever since upgrading to Android 12, I've been getting serious battery drain issues . I have done every solution to try and mitigate the issue, but the software is not optimizing the battery enough.
7 REPLIES 7
Ray1
Expert Level 3
Have you done the cache wiping proceedure and went to settings, Battery and see which app or apps are draining your battery??
AndroidGuy
Yes I have tried that, it does not change anything on my end.
MAP
A lot of people have this issue one of my friend had an s20 and was the same since the android 12 update...
Babs21
Beginner Level 4
Same here
Helenna
Hi, Could you please check battery status in Samsung Members app.
1. Open the Samsung Members app on your Galaxy devices.
2. Tap the Get help option from the bottom of the screen and select View Tests.
3. Tap Battery status.
4. Here, you’ll see information related to your Galaxy phone battery such as Battery power, Life, Capacity and, Charging.
In the case of battery life or battery health, you’ll have the following results: Good, Normal, Weak.
inukshuk83
have The same Phone and no PROBLEMs at all
Montreal1
We have 2, and never, never had any problem. We are with Samsung since S5, and we never had problem, compared to the Iphones with which we had several problems.
