[Fixed/ normal] S20 FE 5g Battery drains more after Android 12 updates
(Topic created on: 02-09-2022 09:24 AM)
Ry98
Hello I've noticed that my S20 fe 5g battery is going down a bit more quickly after getting the update, it's only a year old,  and wasn't like this before the update.
I'm just wondering if it's a common thing among others. If so any fixes you did that may have helped?
Thanks have a great day.
7 REPLIES 7
Tristan001
I have noticed the same thing (and I have power saving mode on) I don't why this is happening. It's not a huge deal, I'm still able to get over a day of charge, but it is a concern
Ry98
Same here, since I got the phone I set it's display to the 60hz and use power saving, turn it off when charging etc, I also notice it uses a it more ram. I regularly clear and do the battery optimization when I'm able to
Theblueberry
They are talking about their phones..
Reynaud
Hi, we suggest you to follow these steps and see if it works.
Settings > Apps, choose the target application > Battery > Optimized
Unrestricted : Allow this app to use battery in the background without restrictions. This may reduce your battery life.
Optimized : Optimize based on your usage of this app. Recommended for most apps.
Restricted : Restrict battery usage while this app is running in the background. The app may not work as expected and notifications may be delayed.
Ry98
The thing is I had that all set up before the update, I changed nothing after, I backed up stuff and did what I saw some one saying to do and factory reset it may have helped some but today for example I turned my phone on around 9:50am it's now 6:36 pm it's currently at 54% for the amount of time I was on it, it should only roughly be around 75% or 65 just going off of other times
I regret updating...
Members_cP8pONz
Yes it is same as mine, mine just over 2 months old **bleep**. Previously i still have more than 60% at the end of theday, after updated halfday already drain 50%. Been to service center , they check everytging ok, the only thing they said, just wait for another update and report to community. Thats not helping and frustrated with this new phone .
Ry98
I backed stuff up and done a factory reset as I seen it recommended online, after a few days to a week (or 2) it went back to how it should. Draining much slower, and lasting longer.
