Major battery drain hits Galaxy S23 devices after One UI 7 update
(Topic created on: 05-04-2025 11:48 AM)
untam3d3vil
Note: these are users from other markets where S23 update was released, not Canada.
Samsung’s One UI 7 rollout, based on Android 15, hit the Galaxy S23 series recently, but some users are reporting higher battery drain, sparking chatter on Reddit and Samsung forums.
Samsung’s One UI 7, packed with a revamped UI and Galaxy AI features like Audio Eraser, initially faced a buggy rollout, paused briefly before resuming. Now, Galaxy S23S23+, and S23 Ultra owners are voicing concerns about battery life post-update. A Reddit user with an S23 griped about charging “multiple times a day” for light Reddit and YouTube use.
12 REPLIES 12
Zjking10
You got one ui 7 on s23 I didnt
untam3d3vil
Naah, this is the markets where ppl received the update and are now reporting issues.
Damama1518
I haven't received the update even. Though I am on the strongest 23 fe.
Damama1518
Correction S23 fe
Will712
What you mean strongest s23 FE? Haha
Damama1518
It was auto correct.
Damama1518
Ye it's kinda annoying 😶
untam3d3vil
We all are waiting for the update. Just keep checking, and every time there is a new market receiving the update ☹️
RedDogRabbit
Battery Life has gone down the drain on the S25 Ultra since the last OTA.. I wouldn't be in a hurry to get One UI V7.0, unless Samsung has fixed the battery issue.. I used to easily get 6+ hours of SOT..now I don't even get 4 hours of SOT!
Always on Display was using a LOT, but I have since turned it off.. and still battery lasts about half as long as it did when I got my S25 Ultra!
AOD & System UI are the two biggest problems!
