How do i search for apps in power saving mode?
(Topic created on: 12-28-2023 05:09 AM)
HSSV
Beginner Level 3
After an update im no longer able to search for apps when using battery saving mode. This was my way of opening apps that were not on my home screen. Is there another way to do this?
There used to be a search button in the top right.
5 REPLIES 5
RedDogRabbit
Are you able to search for apps with Battery Saving turned OFF?
You could always try Booting into Recovery & Wipe Cache, but if you can Search for apps with Battery Saving Off, then it might be an intended limitation of Battery Saving mode.
HSSV
Beginner Level 3
Turns out you're right. Seems like it's an intended limitation now. Thanks
Helenna
Hi, please be assured that Samsung always strives to provide the best user experience on the device, We’ll ensure you that it will be considered as feedback and value your time contacting us.
We certainly bring it to our team for further review.
Hopefully, the feature that you are expecting might be added in future.
amitkayem
Beginner Level 4
Same problem with my Galaxy A73. This is no value addition. Wish I had not installed the update.
Samsung must restore the search button in power saver mode.
amitkayem
Beginner Level 4
