More Battery problems
(Topic created on: 01-22-2018 02:57 PM)
timhortons619
So i restarted the phone in safe mode and the battery was fine then when i restarted it back the battery is draining back so i went to gsa battery monitor and i found samsung dex taking up 18% and i dont even own a dex or know how to turn it on.ae5e97cf-40f0-49e3-a5fd-ed14c611b89f.jpg
6 REPLIES 6
Brando
Try going into Settings > apps > Tap 3 dots in top right corner > show system apps >find Samsung Dex home > Storage > Select Uninstall/disable if available > if not try clearing the data on it/clearing the cahce
timhortons619
cant disable it hmm
Brando
then just try clearing the data on it if you don't use it
shaggyskunk
Get BK Disabler from the Play Store and you can Disable "bloat" and System Apps (Use EXTREME CAUTION when Disabling System Apps) However some System Apps can be safely Disabled - ie: CNN - NHL etc.
Here's a screen shot of Dex and you'll note that it's a System App - Again BK Disabler is a useful tool for Non Rooted devices - But Use Caution ⚠ 🐧cc849460-4cba-4ac2-a68e-dd9cf602df43.jpg
Moderator_
Hi @timhortons619! You have been posting about battery for your device quite a lot. The issue seems to be a hardware issue of your device, and it is difficult to diagnose or troubleshoot without physically inspecting your device. Please contact your local Samsung Service Center (http://www.samsung.com/ca/support/servicelocation/). Thanks!
- Nick
timhortons619
I dont think there is a service center anywhere around london or windsor. I have to go to ottawa or toronto right
