JRF1691
01-24-2023 07:03 PM in
Greetings s22 ultra how do you enable the feature to take a note while you're on a call from the dial pad screen , I recently saw a video where the host clicked on the right hand corner three dots and there was a note taking feature my s22 does not have this what version of software do I need or how do I enable it?
3 REPLIES 3
Tallman
01-24-2023 10:00 PM (Last edited 01-24-2023 10:00 PM ) in
While on the phone. Remove your SPen. Hold the pen close to the screen (leave about 1cm height), then press the button on SPen to trigger Air Command. Then create a new note.
Fatwa
01-25-2023 05:52 AM in
I've been requesting a more robust approach to this on the phone app for years. There really should be a large button on the phone interface that splits the screen and launch into a note. Also in the note app, a make call in the hamburger menu that does the same.
