S22 Ultra Camera Problems
(Topic created on: 09-20-2022 04:50 AM)
bicc_knowlocc
Hello. I am having an issue with a language camera on my almost brand new s22 ultra. When I open the camera app my screen all of a sudden becomes leggy while trying to take a picture. I cannot focus on the subject effectively. The latest camera update did nothing to fix this issue. I have tried to Uninstaller and reinstall the app. I have cleared cache etc. I do not know how to fix this. Is anyone else experiencing this issue as well. Help. Thank you
9 REPLIES 9
RedDogRabbit
Cleared Cache from Recovery?
Tried Resetting Camera from the Camera Settings?
bicc_knowlocc
Don't know how to do that. Any of those. It happens especially when there's movement on screen. Are you talking about just resetting the camera settings from the camera settings?
RedDogRabbit
Yes.
bicc_knowlocc
Done. Same problem
RedDogRabbit
And, sorry did you mean, not knowing how to Clear Cache from Recovery?
Other than Clearing Cache from Recovery, and the other things that you tried..
You could use Samsung Members app to run the Diagnostics for the Camera & see if you get any error messages?
If no error messages, then the only other thing that I can think of, backup your device with Smart Switch & Factory Reset.
bicc_knowlocc
Done. Same issue. Thanks for trying tho...
Helenna
Hi, as suggested by RedDogRabbit the only option we have left is to back up your data and factory reset the device.
Here are the links given below to back up data using Smart Switch and to factory reset.
https://www.samsung.com/ca/support/mobile-devices/how-to-transfer-and-backup-data-using-smart-switch...
https://www.samsung.com/ca/support/mobile-devices/galaxy-phone-perform-a-factory-reset/
bicc_knowlocc
Done. Same issue. Still extremely laggy and hard to take pictures with. I've done everything everyone's suggested here to no avail. Thanks samsung. I only buy phones based on camera performance. Maybe I'll sell this one and go back to using my pixel 6 pro till the pixel 7s release.
JulieLaf79
Beginner Level 3
I have the same problem with my S22
