S23 Ultra battery Drain
(Topic created on: 10-14-2023 03:01 PM)
YEB1464
Hi everyone. On Thursday I bought a galaxy watch 6. Since then my s23 ultras battery started to drain really fast. Normally I would use my phone more than 1 day. But now I am using my phone maximum 6 hours I really need help. Do you guys have a solution?
5 Comments
RedDogRabbit
Try the following:
  • Settings > Apps > Samsung Health & Click on it & Scroll down to Battery & Click on it, make sure that it's set to "Optimized". You could also try "Restricted".
  • I don't use a Samsung Watch, but if there's an option to Restrict Background Usage, select that.
It sounds like your watch & Samsung Health on your phone are continually Syncing.
Try this & see if the battery life improves.
YEB1464
Okay I will try it Thanks
Helenna
Thank you RedDogRabbit.
Hi, I request you to please take the help from the given link as well.
https://www.samsung.com/ca/support/mobile-devices/what-to-do-if-the-battery-of-my-new-phone-seems-to...
YEB1464
Of course I will check it right now
Helenna
Hi, can you please let us know that have you tried the above steps. Is your issue resolved?
