S9 Battery
(Topic created on: 03-21-2018 06:45 PM)
Kobs1406
I got my S9 a few days ago, I am wondering how other people's battery life is because mine is doing worse than my S7.
10 Comments
Lifeguard
can you post a picture of your battery usage graph?
Lifeguard
It might just be due to a bigger screen with more pixels using my battery power. Also if you have the always on display that will use more battery too.
Jonathan34
I have the S9+ and my battery is doing great so far. It's at 52% right now after 9h and 16 minutes off charge, estimated remaining time is 7h 22 minutes.
lacers
That's good news!!!
I love my S7 but I can't wait to get my hands on the S9!!!
How much screen on time are you typically getting?
Kobs1406
Checking the battery info, it is definitely the screen consuming the battery.
RobertZ
Turn turn the brightness as much as possible. I meant at the display brightness to be just enough and I find it saves a fair bit of battery power.
Moderator_
Hey @Kobs1406, could you please contact your local Samsung Service Center (http://www.samsung.com/ca/support/servicelocation/) for physical inspection? Thanks!
- Wonchul
My battery on my S9+ is beyond amazing, so much better than my S8 and even my S7 and S6
Although...this is my first Plus device so it does have a bigger battery!
