Samsung s23 ultra battery draining so fast since the ui6.1
(Topic created on: 04-04-2024 08:21 PM)
fox2
That's the second time in 2 days that my battery of my Samsung s23 ultra goes to 0.... Never had any battery problem before the new update. Am I the only one ?! Thanks
7 Comments
fox2
Speech recognition and synthesis is the problem... It's drawing my battery like crazy .. how do we stop that ***.. ! Thanks
jamesy
You can try restricting the battery usage in the settings and see if you see an improvement.1712301444289.jpg
fox2
That's not normal that I need to do that .. to have battery for few hours ...
fox2
And when you do a search in Google ... People have draining battery problem with that *** since years ... And now I have the same problem.
fox2
And by the way I'm using that ok google thing and other speech ... 2 time this month... How the *** he's running all the time and draining my cell like that since the update ?!
Helenna
Hey fox2, that's so sad to hear that the battery draining fast after the update.
Are you talking about the Google assistant? Is it draining the device's battery faster?
fox2
I uninstalled Speech Recognition and Synthesis from Google and everything is good now ... Before it was drawing like 47% my battery in one day and I was not using it... And that's the problem since the update :(
