02-02-2025 10:16 PM in
Galaxy S- Mark as New
05-18-2025 10:16 PM in
Galaxy SVi muchos comentarios de marzo, que sospechaban que el problema se podia solucionar con las actualizaciones. Alguien pudo solucionarlo? Realmente es pésima la calidad. Este es un ejemplo de selfie de noche.
02-03-2025 05:32 AM in
Galaxy SHi brotz68,
Thank you for sharing your experience with the Galaxy S25 Ultra. We understand how frustrating it can be to expect an upgrade in camera performance, only to see unexpected results.
Based on your description, it sounds like the aggressive processing, particularly in low-light conditions, could be a software-related issue. Samsung often fine-tunes camera performance through updates after launch, so we recommend checking for any available software updates under Settings > Software Update > Download and Install.
Troubleshooting Steps:
Reset Camera Settings – Go to Camera Settings > Reset Settings and test again.
Turn Off Scene Optimizer – This can sometimes cause excessive processing.
Use Expert RAW – Try capturing low-light shots in Expert RAW mode to see if the results are better.
Check Camera Firmware – Settings > Apps > Camera > Camera Settings to see if an update is available.
Test Safe Mode – Restart your device in Safe Mode (Press and hold power > Tap & hold "Power Off" > Select "Safe Mode") to see if third-party apps are affecting camera performance.
We appreciate your feedback and will pass this along to the team. Please keep us updated!
02-03-2025 05:46 AM in
Galaxy SI did attempt most of what you suggested to possibly resolve the issues I've been having. I've tried checking for software updates, camera firmware updates, resetting camera settings, trying Expert RAW, turning off scene optimizer, and trying a third-party camera application. The only "fix" I seem to have found is turning off scene optimizer. With scene optimizer off, pictures are cleaner, less grainy, and more natural. Without scene optimizer, though, pictures often lack extra processing to fix darkened areas or excessive grain, and it's a feature that I expect Samsung to fix and restore its intended functionality. Expert RAW also has its own set of issues, with even more aggressive processing in low-light situations, and worse artifacting in extremely low-light conditions. Expert RAW also shows strange grid-like lines around brighter lights, particularly coloured lights, like LED strip lights, standing light bars, etc. So far, I've resorted to staying away from scene optimizer, not using night mode, only using Expert RAW in medium low-light conditions, and avoiding Expert RAW in very bright light, as well as very low light. These are areas that I expect Samsung to fix soon. I did brace myself for launch issues with software, as any new generation devices usually experience. Thank you for reaching out to help resolve these issues.
02-03-2025 07:11 AM in
02-03-2025 07:15 AM in
02-03-2025 02:45 PM in
Galaxy SI am facing same issue. See thread: https://eu.community.samsung.com/t5/galaxy-s25-series/camera-has-horizontal-and-vertical-lines-in-lo...
I have started the return for the device.
02-03-2025 03:04 PM in
02-04-2025 02:37 PM in
Galaxy SThe photo of the room clearly shows very unsightly errors and artifacts. Take a look at the ceiling of the room... the color artifacts are very creepy and you can also see them in daylight sky photos. You just have to edit such a photo a bit, e.g. with Snapseed, and then it becomes even clearer. This is absolutely unacceptable for such a device.
02-04-2025 03:10 PM in
02-04-2025 03:10 AM in
Galaxy SI usually take pictures of the moon with my S22 ultra. Yesterday I have tried the S5 ultra after receiving it and try a couple of shots...the patterns you mention are extremely visible due to processing, the problem is that for moon shots is almost impossible to deactivate this...to be honest not even against my old S22 ultra I think the S25 ultra is a big improvement
