Wifi power saving mode
(Topic created on: 10-14-2024 06:16 PM)
Anderson199214
Others
I need more detailed explanation on this mode !
4 REPLIES 4
RedDogRabbit
Others
WiFi power savings mode, will limit some background activities, ie: if you have Auto Update apps on WiFi.. if WiFi power savings is on, the apps won't update.
A good WiFi connection, uses a lot less battery than Mobile Data.. so WiFi is already saving some battery life.
I'm not sure how much battery life WiFi Power Saving mode will be saved, I imagine just a little bit.
Others
Ohh ok
Helenna
Others
Hi Anderson199214,
We are good to see that you found the required information from RedRedDogRabbit about Intelligent Wi-Fi mode.
Thank you RedDogRabbit.
Others
I see a difference when the wifi power saving mode is on
Longer battery life without compromised on performance when I'm doing speedtests ❤🔥
