Resolved! Solved
S23 Ultra Battery Drain After Feb Update
(Topic created on: 02-19-2024 08:27 AM)
mickinetsystems
Solutions & Tips
Ok so I am gonna say it. After the February update on the S23 Ultra, I have noticed serious battery drain. The issue is the S23 Ultra is not my main phone so I dont use it that often. Previously it could be there for 2 days before running outta juice since I dont use it that much.
Now, it doesn,t even last a day with little to no usage. After the update, Device Care informed me that MS Word was over using my battery and I uninstalled it. I don't even have much apps installed.
Something must be off with this update. Has anyone noticed same experience?
Resolved!
32 REPLIES 32
Samsung_QNlAHKV
Beginner Level 3
Solutions & Tips
Please don't post useless "solutions"
Helenna
Solutions & Tips
Hi, we request you to please follow the steps in the given link and check again the performence of your Battery.
https://www.samsung.com/ca/support/mobile-devices/what-to-do-if-the-battery-of-my-new-phone-seems-to...
RedDogRabbit
Solutions & Tips
"The Given Link"?
Could at LEAST post a link regarding the Battery Drainage Issue, NOT a general link to Samsung Support.
This is the link you posted..
RobertZ
Solutions & Tips
Samsung, please get someone who is actually knowledgeable on the subject matter to assist your members.
Solutions & Tips
Go check my post on my profile about the adaptive battery setting
Samsung_Ben
Solutions & Tips
Hi mickinetsystems, there are some rare edge cases where certain apps are not fully optimized after a software update.
As RedDogRabbit and Al-001 wrote, it is often recommended to reinstall apps that are causing problems to your battery's performance, clear the app's cache, put the app manually into sleep, or even do a wipe cache partition to reoptimize the entire device.
Should you observe an app that is causing battery drain even after a wipe cache partition or a reset, we recommend you notify the app developers regarding the issue.
Thank you for sharing with us. Thank you RedDogRabbit and Al-001 for your suggestions.
Solutions & Tips
Battery working great now. Thanks
Saransh27
Solutions & Tips
What you did to make it better? I have tried everything  marked by others, still same issue persists.
Also the heating has gone up significantly.
Solutions & Tips
I went to settings >battery and at battery usage, I noticed some unused apps draining my battery unusually. I uninstalled those apps and my issue was fixed
Saransh27
Solutions & Tips
The apps running in background for me are Samsung sharing and Samsung keyboard. No option to delete those.
