Draining battery
(Topic created on: 05-20-2023 09:12 AM)
esanemmanuel
Wearables
My bud2pro battery draining faster
1 REPLY 1
Helenna
Wearables
Hi, you can perform reset the earbuds, and to do that, follow the steps below:
  • First, place the earbuds in the charging case for 15-20 seconds and again put them back into your ears.
  • Then, you need to disable Bluetooth on the connected device for around 20 seconds and later enable it again.
  • Now, open the Galaxy Wearable app.
  • Then, go to About Earbuds.
  • Finally, click Reset Earbuds.
Due to dirt deposits on the charging case terminals, sometimes they malfunction during overhaul charging. As a result, you think the charging case is usually charging, but in reality, the case does not entirely recharge.
You feel your Galaxy Buds 2 Pro battery draining. So ensure that your charging case terminals are clean.
If earbuds are not in use, leave them inside its charging case ensuring that the charging case lid is closed.
