08-27-2020 08:50 AM in
WearablesMy left bud on my galaxy buds+ all of a sudden won't connect.
I have opened and closed the case, plugged in the charger, rest the buds, disconnected the buds, reconnected the buds, restarted my phone, factory rest the buds.
None of this is working.
Can someone please help?
thank you,
08-27-2020 09:03 AM (Last edited 08-27-2020 09:09 AM ) in
WearablesIf this happened after a major android update , please try wipe cache partition
Sometimes, on mine, i have to clean them or connections are bad and they can charge, check how here : here is the link to clean your Earbuds
https://www.samsung.com/ca/support/mobile-devices/galaxy-buds-clean/
Normal steps but you tried them..so try wiping the cache ..what is your device ?
Please open the Galaxy Wearable app >> press the touchpad >> press Left or Right under Press and hold the touchpad >> Select volume down / volume up.
Also try resetting the headphones and make sure the Galaxy Wearable app is updated.
Follow the steps below to reset the buttons:
Open the Galaxy Wearable app >> Select About Headphones >> Tap Reset Headphones >> Tap Reset Headphones.
08-27-2020 09:29 AM in
Wearables- Mark as New
08-27-2020 05:58 PM in
Wearables
